problem with NI-IMAQ for usb
hi. i have labview 8.0 and vision 7.1. i installed ni-imaq for usb but the vi blocks didn't appear in function palet. does ni-imaq work with labview 8.0 and is it important to have the same labview and vision? if there is a new version of ni-imaq to work with labview 8.0 please send me the link.
(2,490 Views)
Ali,
    As far as compatibility, LabVIEW 8.0 is compatible with Vision 8.0, 8.2, and 8.2.1 -- it is not compatible with Vision 7.1 so that may be causing the issues you are seeing.  LabVIEW versions are only compatible with the same, and newer versions of Vision.  As far as IMAQ, here is a link to the Version Compatibilities of LabVIEW and IMAQ.  Let me know if you have more questions!
-Allison S.
Calibration Services
Product Support Engineer
(2,472 Views)
