06-14-2007 12:28 PM
06-17-2007 09:45 PM
Hi David2H,
Thanks for posting on the discussion forums. Unfortunately this function in MAX is very limited in its functionality, and is only used for quick easy transfers of data. The best solution to this problem would be to have the LabVIEW program that the data is collected in also create an output file you could work with. If you feel that MAX needs this functionality you can propose a product suggestion here.
