problem with 3D graph
shout I creat a new question for how to export results?
how can I control X and Y of the intensity graph as you did with 3D graph?
In the intensity graph as you see, X axis shows the nomber of itérations and not the real values of my voltage.ni q3.PNG
Message 11 of 17
(1,194 Views)
Or search first... Related questions pass at least once a week.
how can I control X and Y of the intensity graph as you did with 3D graph? In the intensity graph as you see, X axis shows the nomber of itérations and not the real values of my voltage.
You need to set the offset and multiplier of the X and Y scale with property nodes.
Those scales are linear, the distance between 2 points is always the same... So you can't have Z-values at arbitrairy X\Y positions. In other words, the X\Y values are a fixed grid. The X and Y offset and dX\dY can be changed though.
Message 12 of 17
(1,190 Views)
 can you help me with it.
I want Vg as my X axis, Vds as my Y axis.
Message 13 of 17
(1,187 Views)
You can use one property node, and extract it to 4 items.
Right click the property node, and change it to Write.
Message 14 of 17
(1,184 Views)
Message 15 of 17
(1,182 Views)
Accepted by vispacespace123
okay am I doing right? and what next
Press CTRL+h, and you'll get help on those items when hovering with the mouse.
Wire things to it, and see the scale change. I couldn't recommend what to wire to it, because I have no idea what is right.
Basically, the offset is the lowest value (now 0) and the multiplier is the delta (now 1)...
Message 16 of 17
(1,168 Views)
thank you
Message 17 of 17
(1,156 Views)
