problem w/ Measurement automation explorer or Inst I/O Asst
I am new to Labview, and am working my way through the tutorial. I have loaded 3 discs for Measurement Automation Explorer such that i may complete Ch.4 of Getting started w/ Labview, using a DAQ device. The portion where i place an Instrument I/O Assistant on the block diagram is holding me up. When i double click the sub VI, it pops up an error message telling me that "Measurement automation explorer or Instrument I/O Assistant is not installed correctly". I have loaded these disk's twice so far, same issues. No one around the office can figure it out, either. I am using Labview disks dated Feb. 2007, NI MAX 4.2, compliance package 3.0, NI DAQmx 8.5. Any help is greatly appreciated. Thank you.
(3,026 Views)
Thanks for all the great responses, your help was much appreciated. I couldn't have figured it out without y'all!!
(3,004 Views)
Accepted by topic author Navynuke
Hey,
Try the solution that is presented in this KnowledgeBase article.
Sara Lewandroski
Applications Engineer | National Instruments
(2,996 Views)
Thank you. I did that, yesterday, as i managed to stumble upon the solution by accident. Now i have run into another issue...see my latest post. Help on this topic would be greatly appreciated. Thanks again.
-Jon
(2,987 Views)
