change 2D array in 3D array and send back
HEllo,
I have simple problem but dificult for me.
A have 3D array of data 12 pages with 4x 10 array od data, descibing my sensor in different situation.
I need to calibrate sensor in each situation and I have to take out 2D array from 3D array, change 2D array and remember as new 3D array and use it later.
I understand that all pages must be equal dimension which is not ideal for me but I can live with that.
For some reason attached VI does not work right.
Sasa
(3,137 Views)
You don't say in which way it "does not work right", but I can take a few wild guesses.
  1. You have a race condition because the various numerics are read right after each iteration, so even if you change them later and press e.g. "add", the stale value is read from the tunnel. These terminals belong inside the event structure so they are read only after the event triggers.
  2. Your "Lookup" control is located outside the main loop, so even though you write to a local variable of it, the data in the tunnel is still stale, because the control only gets read once at program start. Again, the terminal belongs inside.
  3. It would be better to keep the lookup data in a shift register.
  4. You don't need to transpose twice. Simply wire the "kolona" to the lower index to operate on columns.
(3,116 Views)
(3,108 Views)
Thank you. This look as god solution for this.
I modified in sense that I can measure during event waiting and when I found god value I remember it to the 3D array.
I try to add table so that I can see visualy my coloumn index eg I will color later. When I change the column value I loose all values, even if my event for column is empty.
Any idea ?
Regards
(3,072 Views)
Accepted by topic author sasko
You need to wire the 3D array across in all event cases. Else it resets to default (=empty array) whenever an unwired event case executes.
(3,062 Views)
