printing and saving the xy-graph data
Hi everyone!!
I want print and save the xy-gaph data...
I may know how I can save the data (I´m not sure) but it won´t save the curve...obviously it only saves the data points!
If I want print the xy-grap displayed data, how I can do that?
Message 1 of 26
(3,995 Views)
Hi
Due to the fact that your source is german, I assume that this thread may be helpful.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 26
(3,972 Views)
Thanks for the thread, but if someone can help me in English...I would be very happy...
Message 3 of 26
(3,970 Views)
Ok - so I'll try ;).
There are several ways to print your data.
Very simple are Reports - there you could insert control image (for example of a graph) and print it out.
You could also print the whole front panel. For this create a reference of the vi you want to print, wire it to an invoke node and select the "Print Panel To Printer" method.
Thomas
Using LV8.0
Message 4 of 26
(3,967 Views)
Thanks for the advise Thomas!!
Can you little bit specified what you mean Reports - there you could insert control image?? I have now the reports printing but how I can insert the control image?? And how I can create the refere...
Message 5 of 26
(3,961 Views)
and how I can create reference of the vi?
Message 6 of 26
(3,958 Views)
Message 7 of 26
(3,958 Views)
Hi
There's a vi called "Append Control Image to Report". You can pass a control-reference to this vi, and the control will be printed.
I attach you a simple solution.
Hope it helps.
Thomas
Using LV8.0
Message 8 of 26
(3,955 Views)
Well it´s looks okay...Only what is not correct is the new report.vi
Do I need something more in question new report.vi ?
Message 9 of 26
(3,947 Views)
What do you mean with "is not correct"?
If I look at your vi, everything seems to be ok.
Using LV8.0
Message 10 of 26
(3,936 Views)
