printing and saving the xy-graph data
well...If you mean that it won´t help...(see a file)
Do I must save first the graphs and then print it out...?
Message 21 of 26
(1,089 Views)
No, you don't have to save them.
The "Append Control Image To Report" vi puts an image of the graph control on the report as you see it on the front panel.
So your attached vi should work - or is there any other problem?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 22 of 26
(1,085 Views)
well...It think so too that it should work, but as you can see if you try use tha program it gives same error that
what I have told you..."appnd control image to report.vi is not acceptable"...Least if I try to use...
Message 23 of 26
(1,083 Views)
Well - that's really strange.
If I open your vi everything seems to be ok. Is it possible for you to post a screenshot of your blockdiagram?
Using LV8.0
Message 24 of 26
(1,078 Views)
well...I chanced computer an the error was gone...:-) I don´t know why... but now another computer gives the error:
SubVI DAQ mxBase Read (Digital U8 1 chan 1 samp).vi - is not acceptable...
Message 25 of 26
(1,075 Views)
As already mentioned I can't help you on this topic.
I'd suggest you to post it in a new thread.
Thomas
Using LV8.0
Message 26 of 26
(1,067 Views)
