printing and saving the xy-graph data
The program won´t start...It´s give messages "SubVI ´New Report.vi´ : ungültiger link zum SubVI"
also DAWmxBase Read. vi would gives error...polymorphes SubVI nicht ausführbar
Message 11 of 26
(1,894 Views)
Obviously you use the standard report generation. I use the Office report generation toolkit.
I assume that the "New Report" vi is a bit brighter if you open the block diagram.
So to solve your problem, right-click the vi and select "Relink to Subvi".
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 12 of 26
(1,885 Views)
Thanks for help Thomas!!
Only error what program would gives is "Poly VI- DAQmxBase Read.Vi - Polymorphes SubVi nicht ausführbar
If I click the right button and open the polymorphes VI, it shows the error but how I can handle that or remove its?
Message 13 of 26
(1,882 Views)
I'm not sure because I don't use DAQmxBase vis.
But maybe it helps, if you delete this vi, save your vi and close all. Afterwards you can open your vi again and insert the DAQmxBase Read vi again.
As I said - I'm not sure about that, but just have a try. Maybe it works.
Thomas
Using LV8.0
Message 14 of 26
(1,874 Views)
can someone tell me what is wrong in my vi´s...
Error is connected printing operation...program gives a error that append control image to report.vi is not acceptable...what should I add in this vi that it would works properly...?
Message 15 of 26
(1,859 Views)
Hi
For me it looks like as if LV can't manage references of graphs containing dynamic data.
Wire the double data to the graph and it should work.
Thomas
Using LV8.0
Message 16 of 26
(1,851 Views)
What you mean "double data to the graph"... ?
Message 17 of 26
(1,842 Views)
You wire a double array to the "convert to dynamic data" vi and this is wired to a graph.
Wire the double array (the orange wire) to the graph.
Using LV8.0
Message 18 of 26
(1,838 Views)
I have tried do that but it not allow that...it would add automatically "convert to dynamic data" when I try to wire double array in the xy graph...
Message 19 of 26
(1,834 Views)
There's a difference between a waveform- and a xy-graph.
The waveform-graph accepts double or waveform data, whereas the xy-graph accepts a cluster of x- and y-values.
Put a new waveform-graph on the front-panel and wire the double-data I mentioned in my previous post to it.
This should work.
Thomas
Using LV8.0
Message 20 of 26
(1,825 Views)
