precision property node in numerical value
I found there had a problem in the "precision" property of numercial value.
FREQUENTLY, my simple code showed an error message (attachment).
Sometimes, the code was Okay randomly.
Is it bug or any other solution?
메시지가 08-07-2007 11:49 PM에 labmaster에 의해 편집되었음
메시지가 08-07-2007 11:50 PM에 labmaster에 의해 편집되었음
(3,227 Views)
Can you attach the program instead of an image? What is our LabVIEW version?
A property such as this needs only to be set when the desired value is different. It seems you are setting the same old property millions of times per second.
(3,209 Views)
Thank you for your interesting.
I attach the vi (LV ver8.2.1) for your review.
(3,202 Views)
Set the format of your indicator to floating point (right-click...format&precision). You had it on automatic formatting.
(3,199 Views)
