ploting a XY graph with 2 y axis vs single x axis
Hi ,
   I am trying to plot a XY graph with 2 Y axis in left hand and right hand sides vs a single X axis.
Using duplicate scale and swap scale am able to create the graph with 2 Y axis but am not able to connect the 3 arrays to the graph.  I am using labview 8.0 and with this am attaching a sample code also. please help me for that..
thanks in advance..
     Nikhil
Message 1 of 8
(4,498 Views)
Accepted by M1014757
Hi Nikhil,
cluster first the data for each xy plot and use then the build array function.
Mike
Message 2 of 8
(4,495 Views)
Hi Mike,
thanks a lot ..thats the solution.. i got it, but due to some setting problem i am getting only single plot.
can you help me for that..
Nikhil
Message 3 of 8
(4,485 Views)
Find the vi
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 4 of 8
(4,468 Views)
Hi Baji,
i am using labview 8.0 version, can you send me a lower version vi. or a picture of that vi.
nikhil
Message 5 of 8
(4,460 Views)
Hi nikhil,
resize your plot legend to two. Right click to each plot and assign the specified y-axis.
Mike
Message 6 of 8
(4,455 Views)
Find the vi in 8.0
Balaji PK (CLA)
Message 7 of 8
(4,453 Views)
Hi Mike,
Yes i got it, thanks a lot ..
Nikhil
Message 8 of 8
(4,440 Views)
