place an image on the block diagram
It's hard to tell from the picture, but either you can paste an image right over your code, or those other two wires arent connected to anything.
But I'm assuming that its the former of the two options.
Cory K
Message 21 of 35
(1,929 Views)
I think if they were disconnected wires, they'd show up as broken.  My guess is there is some sort of label that contains only spaces overlaying those wires.
Message 22 of 35
(1,910 Views)
Cory and Ravens,
 Of course you are right, the wires are hidden (I have used an image of the BD)... This is obvious. So the challenge is elsewere : is it possible to make the wires visible ? 😉
Message Edité par chilly charly le 01-11-2009 06:10 PM
Chilly Charly    (aka CC)
Message 23 of 35
(1,900 Views)
I did not figure out the answer to your question CC.
But I did figure out that only the wires are hidden by images,
functions can be moved above/below the image.
Cory K
Message 24 of 35
(1,886 Views)
That's it ! It is not possible to have an image as true background on a block diagram. The wires are always hidden (except if the image contains transparent regions). I don't think this is the way things should work, so it's probably a bug.
Message 25 of 35
(1,877 Views)
Go ahead and report it!
Lets see if it gets fixed before or after the copy form the hiarchy screen bug. (and I did not think cob-webs could grow in a spread sheet).
Ben
Message 26 of 35
(1,861 Views)
Done... waiting for a CAR... 😉
Message 27 of 35
(1,837 Views)
So now that it has been reported...
NOTE to NI R&D
Removing the ability to add an image to the diagram is NOT a viable fix. Smiley Surprised
If we have to choose, between geeting the bug reported by CC fixed and having the ability to include images, we can live with the bug.
Ben
Message 28 of 35
(1,835 Views)
Hi chilly charly,
Did you already report this, and if so, what is the CAR # (so I can add Ben's request to the CAR notes)?
Jeremy_B
Applications Engineer
Message 29 of 35
(1,806 Views)
Hi Jeremy,
Reported on the January bug list. No car yet.
Message 30 of 35
(1,792 Views)
