pci 6225 problems
Hi all
I am trying to acquire data from a function generator using NI PCI 6225. When i give any voltage it shows only -10.5 in the wavform. I do not understand if it is a problem of hardware or any other problem.
rgds
Rajan
Message 1 of 9
(4,316 Views)
Hi Rajan,
did you try to capture this signal in MAX? Do you see the same problems there?
Mike
Message 2 of 9
(4,309 Views)
yes mike,by the way i am using scb 68 connector box. Do i need to any seperate connection for this box in MAX?? do i need to create it seperately???
Message 3 of 9
(4,307 Views)
Hi gangaputra,
no, you don't need to change the hardware. Start the Measurement and Automation Explorer (MAX), go to devices, select your PCI 6225 and select test panel. Select the channel you connect your device to and start the acquisition.
Mike
Message Edited by MikeS81 on 02-11-2009 01:15 PM
Message 4 of 9
(4,302 Views)
i tried it several times but it gives the same error,,,:smileysad:
i am connecting the function generator's positive to pin 54 and negative to pin 22,,,,and scb 68 is connected in connector 0(0-16)
Thank you very much for replying so soon
rgds
Rajan
Message 5 of 9
(4,295 Views)
Hi Rajan,
in my description pin 54 is AO ground and 22 is AO0. I thought you want to acquire data, so you need an input.
Mike
Message 6 of 9
(4,292 Views)
yes i want to acquire data. so,,,how do i do it???
Message 7 of 9
(4,289 Views)
Hi Rajan,
if you right click in your device in MAX, then you can see the pin assignment. For an input you can use connector 67 and 68.
Mike
Message 8 of 9
(4,284 Views)
thank you very much mike. it works well now
thank you very much
rgds
Rajan
Message 9 of 9
(4,282 Views)
