which file system?!
hi,
i want to use the cRIO - system to log a huge amount of data in the fastest way that's possible. (file size about 50.000 measured data)
i want to read or write data from/to an usb device, which is connected to the cRIO controller, for a long time (a few hours) and i'm looking for the best file system that can handle it in the fastest way.
i'm thinking about to use a fifo-dma to read data very fast from the usb-device and transfer it to the fpga and then indicates these data (read from usb-case) or i read data from an analog module and write it via fifo-dma from the fpga to the host and save it on the usb-device (write to usb-case).
so my question is: what file system should i use to do this? (*.tdms, *.tms, *.xml, *.txt, ...)
what's the big differences between this file systems?
thanks for your reply,
best regards,
Simon Gabriel
(3,117 Views)
Hey,
If you wanna put additional information together with your data you should use TDMS. If you just need to write I32 data or a selfbuild format like a cluster then I would suggest to use binary file I/O functions. You will find some information about TDMS here: http://zone.ni.com/devzone/cda/tut/p/id/5696
Christian
(3,076 Views)
