parallel port switcher
Hi all,
I have attached a parallel port switcher that I downloaded but I keep getting the error "manager call not supported" as attached.
How can I run/ use the attached vi? I have Labview 7 and Labview 8.5 installed, in my Windows XP and Windows 2000.
(2,935 Views)
Hi all,
I've soldered 3 LEDs to pin 2, pin 6 and pin 9 and pin 25 to ground. I need to control the on off of the 3 pins through Labview. I've modified an example I found in Labview as attached but there are things that I don't understand:
1. Why is it when I clicked both LED 18 and 22 on Labview, all my 3 LED on breadboard (connectted to pin 2,6,9) turned on?
2. Why is the "register write value" in Labview consists of 32 LEDs? How can I change it to may be 8 or 3 LED?
3. If I change the "register write value" to constant, what value or number should I insert to on/ off my LED?
Please advice.
Kim
(2,916 Views)
That subVI in your first message is fairly old and poorly written.  My installation of LV didn't even link to all of the subVI's.  I would recommend that you search the example finder for Parallel Port and use one of those examples as the basis of your code.
(2,910 Views)
