Subvi parallel loop terminations
Hi all,
I have multiple parallel loops (all in subvi).  What do you think is the most elegant way of implementing a clean user termination for all of the parallel loops inside subvis?  I want to hear what you think.  Thanks!
(3,095 Views)
Generally a local variable shoud be enough.  But there are a few more questions.  Is the front panel being opened when the subVI is called?  What is the condition where you want the subVI to stop?  Is it based on some data, a user interface action?  What does the subVI do?  Why do you have a loop in a subVI?
(3,094 Views)
