one wire driver
I need the driver of one wire to DS18B20 temperature sensor for labview 2013, I tried to install it using the VI Package Manager but it doesn't work, I think it is because that the driver is in the VI Package Manager is compatible with labview 2012.
Message 1 of 15
(6,342 Views)
Have you check the VI Server settings as mentionned in the dialog message?
Message 2 of 15
(6,313 Views)
thank you for the answer, but how can I check the VI Server settings as mentionned in the dialog message?
Message 3 of 15
(6,301 Views)
Accepted by topic author anouardz
In LabVIEW go under "Tools"->"Options..." and select VI Server, see in image below. What the dialog says is that you need to have the "localhost" in "Exported VI".
Message 4 of 15
(6,287 Views)
thank you very much, it works very well. but I thought that when I installe this driver, it is added to the Arduino library that I can use with Arduino and DS18B20, as what is given at the end of this video !!! https://www.youtube.com/watch?v=SM_c0cN-Kgs&feature=player_embedded
Message 5 of 15
(6,274 Views)
You need to be looking for an arduino sketch if you need code to ruin on the arduino.
Message 6 of 15
(6,258 Views)
but after installing one wire from the VI Package Manager I found nothing new thing in arduino (figure below) I checked : low level, sensors, utility, examples. and I searched on the internet the driver of one wire (DS18B20) to Arduino and i found nothing.
Message 7 of 15
(6,248 Views)
The VI you installed has nothing to do with the arduino. It is for connecting the pc to a one wire device.
Message 8 of 15
(6,228 Views)
But if I want to use Arduino + DS18B20 + labview there is a solution?
Message 9 of 15
(6,214 Views)
Presumably, but you have to find some arduino code to interface to the device add I have already said. Once you have done that, then the arduino will send the readings to the pc and you can read them with LabVIEW and the VISA serial port functions. This board is NOT for helping with the arduino c functions. For that, you need to post to s board specific to arduino.
Message 10 of 15
(6,204 Views)
