Remove 0's from Graph
Hi
Im trying to plot some values that represent data recorded with 5 second intervals. The 2 plots is a mean value and a peak value. I would ideally want a line between the mean values. However in the dataset there's values that equals zero, so my graph drops to zero when this happens.
How can i remove these points from the graph?
I still want to keep the distance as if the point was still there.
Hope someone can help me out here.
/ Maarten
Message 1 of 10
(6,874 Views)
You could use a FOR loop to replace all of the elements in the array that are equal to 0 with NaN.
Message 2 of 10
(6,855 Views)
That will remove the zeroes but there will be no lines between the pre and post zero data (an acceptable solution in my mind if the frequency of 0 appearance is low).
Ben64
Message 3 of 10
(6,845 Views)
Your solution will probably not work, as theres is periods where a larger amount of the data is 0. But thanks for the response. I will see if i can find a better way to show the data.
Message 4 of 10
(6,832 Views)
You could replace a 0 with the latest previous non zero value. To have a line joining pre and post zero value you need to know the post value and there can be more than 1 consecutive 0 zero, this can get complicated to calculate the line equation and the y value of the point to replace (althought possible).
Ben64
Message 5 of 10
(6,819 Views)
I guess we're assuming that the 0's are not real data?  Just checking.
Bill
CLD
(Mid-Level minion.)
Message 6 of 10
(6,805 Views)
Well its "data" recorded at a specific time that says: ---,-  in the .txt file.
So its not really 0, its just data that for some reason is not available at the specific time.
When i use the read from spreadsheet function in Labview the ---,- is converted to 0.
The format in the .txt file is like this, where i'm only interessted in the last two columns:
1        ----       23.01.2002     09:06:00     70,4      94,7
2        ----       23.01.2002     09:06:05     ---,-       ---,-
3        ----       23.01.2002     09:06:10     72,3     93,1
So basically what i want is the X axis to represent the time, but not plot when no data is available.
Message 7 of 10
(6,795 Views)
I like Ben64's idea, then.  🙂
It's not critical, then?  The bad data point doesn't need to be flagged as asuch?
Bill
CLD
(Mid-Level minion.)
Message 8 of 10
(6,772 Views)
No they don't need to be flagged, just not in included on the graph.
After some considerations i don't think i will implement a line between the data points, just show them as a dot.
So i will go for Ben64/crossrulz solution, to replace the 0's with NaN, so they won't show up on the graph. With this i will still keep my time axis intact. 🙂
Message 9 of 10
(6,763 Views)
Could also use an XY plot, since you have time use this real value as the x axis and data as the Y, remove time data pairs where the data is out of range (ie ==0)
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 10 of 10
(6,723 Views)
