numeric values
I am very new to labview...
I want to read a value from and instrument be able to change it and then write it back.
I would like to use a numeric indicator to display the value from the instrument and a control to change it. My problem lies in getting a numeric control to initially display the value from the instrument.
thanks   steve
Message 1 of 8
(4,494 Views)
thanks   steve
This is one case were I recommend using a local variable of your control. With that you can write a value to the control. Just be aware that using local variables introduce the possibility of race conditions.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,493 Views)
Please include a Snippet of your code, or attach your VIs, so that we can better assist you. As mentioned already, a simple local variable should do the trick.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 3 of 8
(4,472 Views)
What instrument?  How are you getting the data from the instrument?  How is the said data formatted?  What else is your VI doing?  How often do you need to read the value?
Message 4 of 8
(4,440 Views)
thanks   the simple variable worked
Message 5 of 8
(4,415 Views)
Then please mark Mark's post as solution. Potentially give a kudo...
Message 6 of 8
(4,398 Views)
I have never heard of a "simple variable". Can you explain what you did?
Message 7 of 8
(4,382 Views)
A "simple local variable" was mentioned as solution. So I'd bet a local variable was used, and it was referred to as simple variable.
Message 8 of 8
(4,360 Views)
