Manipulating 2D Array to Emulate DAQ Express Calibration stage
Hi there,
It would be great if anyone could help.
Im trying to manipulte a 2D array of data which has been produced (Will be produced programatically but just a constant at the moment) to represent the calibration points of a set of transducers/instruments. The reason I need to manipulate the array is that I need to split the data into sets of 2D arrays which represent each transducer then feed into the linear Interpolate function.
I can prove the concept works with just one array 10x2 but not when the array has two data sets, i.e without trying to split the array with a for loop.
I am essentially trying to emulate the inbuilt calibration function inherent in DAQ Express but without using DAQ express or allowing people to fiddle with NIMAX to great channels.
I have attached my code snippet so far (Should be in LV2014) if any one can help.Snippett.png
(2,992 Views)
Hi Alex,
I am not sure what you mean by not working when you have 2 data sets, but you can try this to use the Index Array functions to split a 2D array at a specified index:
https://forums.ni.com/t5/Example-Programs/Split-2D-array/ta-p/3519515
Kind regards,
Kelly
(2,935 Views)
Accepted by topic author Alex.902
Hi Alex,
to manipulate your 2D data you could try this:
The other part in your snippet also has some quite "funny" code: why do you need to typecast a scalar value to an array? Why not use BuildArray instead?
(2,932 Views)
Hi GerdW
Thank you for your reply, your method does indeed work perfectly.
The reason for the type cast is that so far as I understand (which can be extremly lacking) in order to get the Interpolate function to work the "test variable" needs to be in the form of an array, I could use a build array for each but as yet I dont know how many calibration points might be in each array so would have to use a for loop also I would presume?
i.e a flow meter might have;
4mA = 0ltrs/min
20mA = 10ltrs/min
But for accuracy on the transducers I might calibrate over 10 points.
(2,910 Views)
