number to string precision
I want to convert an array to a spreadsheet string. The array has 2 dimensions of seonds,value. Seconds is the value returned by the "Get Date/Time In Seconds" function.
I find that the "Array to Spreadsheet String" function will truncate the seconds value because it is more than 6 digits long.
I can force extra digits by using a format string of "%.9e" which gives an exponential representation with 9 digits of precision.
This is fine but it pads the last few digits with zeroes if they aren't needed.
Is there any trick I'm ignorant of that will convert a number to a string of >6 digits precision and automatically use the correct number of digits to avoid the extra zeroes? I've hunted through online help and this site with no luck so I expect the short answer is "No." but I figure I should ask.
I'm running Labview 5.1.1 on a Mac under OS9 because NI will not supply an OSX driver for the PCI-GPIB boards that we use throughout our experiment.
I know we're crazy, we need to cough up the cash for a different interface, we just so far have not had enough incentive. Do later versions of Labview perhaps overcome the 6 digit limitation?
Thanks.
(3,609 Views)
My bad, as far as the lack of driver for PCI-GPIB. I just remembered that had been released. The reason we haven't switched is that our experiment uses a couple of acquisition systems using the MXI-VXI interface that does not have an OSX driver.
I'm still wondering about the number to string conversion precision thing though...
(3,608 Views)
I've used the attached VI to do what you describe. I format the number, trim off all trailing zeros, check to see if the string then ends in a decimal point and if it does add back in one zero.
(3,602 Views)
Thanks, but I can't open this file with LabView 5.1.1 on a Mac. Is it a later version? Could you post it archived or compressed?
(3,566 Views)
Here is a picture of the block diagram:  In the case structure, case 0.. is shown, case ..-1 is not shown but it is just a straight wire from input to output.  Same with next case, straight wire from input to output for case not shown "".
Message Edited by tbob on 03-21-200605:19 PM
Message Edited by tbob on 03-21-200605:22 PM
- tbob
Inventor of the WORM Global
(3,565 Views)
