niscope initialize
I just reformated my computer and installed labview 8 and NiScope. I use to use labview 7 with NiScope.
Now i get prompted when i run my old applications: "Please locate niScope Initialize.vi"
and many other files are missing aswell.
can anyone tell me where i could find those files?
aleks.
(2,824 Views)
aleks,
When you installed NI-Scope did you select the option of installing support for LabVIEW 8.0?  You can select this option again by going to Add/Remove Programs >> Click on change under National Instruments Software >> NI-Scope >> Modify.  You can now select support for LabVIEW 8.0.  Also, are you still seeing the VIs appear in LabVIEW 7.1?  If this does not work, you could try repairing the NI-Scope driver as well.
Raajit L
(2,809 Views)
