network streams avoid LabVIEW executables to close properly
If I build an application that contains network streams operations, the application process will not be closed after the application stops. This happens even if I use the Quit LabVIEW call !
To examine this I used a simple add function with and without a sequenced  'Create network stream reader endpoint' call. The executable with a network stream call, stays in the process list after stopping the application.
It doesn't matter that the pure create stream call is incomplete to create a stream and is in this way without any functionality. Due to a timeout error no stream will be created, but it ends as described. So this scenario is only to show the behaviour of the executable.
Any ideas ?
Thanks in advance
Christian
(4,317 Views)
For anyone who is interested I attached a sample project. I think this is a bug without workaround.
(4,289 Views)
Sorry I forgot the configuration
LabVIEW 2010 f4
Windows XP SP3 up to date patched
The executable build and failed to close in XP, will be closed correctly under Windows 7 ( tested with 64bit under runtime conditions )
Christian
(4,275 Views)
We already encountered the same problem.
The only way to shut down the "zombie" executable is to open the windows task manager
(STRG+ALT+DEL)--> Task-Manger and then kill the application manually in the process list.
Best Regards
J.P. Oswald
(4,253 Views)
Accepted by christian_w
this is a knowing issue and is already reported to R&D with the
"Corrective Action Request 254821 - Executable with Network Streams leaves Process running in Task Manager in Windows XP".
This issue will be fixed with LV 2010 SP1
Ulrich
AE Specialist – NI-CER
(4,226 Views)
LabVIEW 2010 SP1 will be officially released on Febuary 21st.
Stefan
(4,181 Views)
