mouse position over waveform graph
Hello everyone!
Is it possible to get the data? I am  using waveform graph to present some data. For zooming purposes I need to now the mouse XY position (best with regard to the actual scales of the plot).
Thank You ALL
(7,215 Views)
Accepted by topic author przemmo
One of my most-used methods is the Map Coords to XY
21293iD35258E207330959
(7,207 Views)
There is a vi under 'Input Device Control VIs' called 'Aquire Input Data VI' that can give the x,y position of the mouse.
The graph should have a property that gives it's coordinates.
Jim
(7,206 Views)
There is standard support for mouse-zooming in XY-graphs.
Ton
My LabVIEW Ideas
(7,190 Views)
Yes, there is. I want to zoom the peak (the plot consists of many peaks) that is the closest to the mouse coursor. For this I need to know the x coordinate of mouse arrow.
(7,181 Views)
