mouse position over waveform graph
Hello everyone!
Is it possible to get the data? I am  using waveform graph to present some data. For zooming purposes I need to now the mouse XY position (best with regard to the actual scales of the plot).
Thank You ALL
(7,220 Views)
Accepted by przemmo
One of my most-used methods is the Map Coords to XY
21293iD35258E207330959
(7,212 Views)
There is a vi under 'Input Device Control VIs' called 'Aquire Input Data VI' that can give the x,y position of the mouse.
The graph should have a property that gives it's coordinates.
Jim
(7,211 Views)
There is standard support for mouse-zooming in XY-graphs.
Ton
My LabVIEW Ideas
(7,195 Views)
Yes, there is. I want to zoom the peak (the plot consists of many peaks) that is the closest to the mouse coursor. For this I need to know the x coordinate of mouse arrow.
(7,186 Views)
