modbus problem
Hi everyone,
I am trying to communicate with ADAM card 4024 (4 ch Analog output). I am using Modbus communication. Please check Image of error that i am getting.
Please explain me reason of the error.
Thank you in advance.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,345 Views)
You have no error after the Init (before your loop), as the check box in the upper left corner is a "green X". The error 6101 that you are getting is a timeout error from one of two locations in the MB WR vi, from one of its sub-vi's "MB Serial Receive.vi". There are two places that the 6101 error is generated, one where the program does a "Read the slave address of the query to make sure it's for this slave." the other where it does a "Read the MODBUS frame". The didn't put the code in to determine which of these it is coming from, one method is to go into the code an make a small change to the text where the error is coming from to determine which is causing it. The first indicates that it didn't get the slave address that is supposed to be associated with the data, or just didn't get anything (more likely). I have been having this problem with one of my projects, created a piece code to parse for that error and clear it, retrying the query a preset number of times before actually failing.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,332 Views)
Accepted by Gak
Hi LV_pro,
Thank you for your reply. It was very silly mistake. The card was configured for protocol of "ADVANTECH" Smiley Sad.  I changed it to MODBUS then my program ran very nicely.
Thank you again. Smiley Happy
Gaurav k
CLD Certified !!!!!
(4,297 Views)
Dear Gaurav,
We are also using ADAM 4024 and trying to communicate it with MODBUS. But we have not yet achieved.
we are able to do it with Advantech protocol but not yet succeeded with MODBUS
Can you pl send the code for communicating the ADAM 4024 in MODBUS in LV 2009 Version.
Ramchandra B Chavan
(3,564 Views)
This thread is four years old. I also notice that Gaurav hasn't logged onto this forum since January of this year, so it is unlikely that your request will be seen by him. Since he posted an image of a very simple vi that he was using, why don't you just build one yourself?
Putnam
LabVIEW Champion
(3,558 Views)
