modbus ethernet example
hallo guys,
Í am using Labview Application Builder to creat a exe program based on MB Ethernet Example Slave.vi, but it can not communicate with MB Ethernet Example Master.vi correctly, before building, the original Slave and Master example programs can communicate well, but after turnning MB Ethernet Example Slave.vi into exe program, these two do not work in the desired way, is there anyone confronted this problem before?  Maybe some configeration need to be set during building.
great thanks.
Message 1 of 8
(8,365 Views)
Hi Coolbear,
The first thing to check is the ini file of the exe. Copy the contents of the LabVIEW.ini file into the ini file created for your exe. Permisions and port numbers are defined therein.
Ben
(aka Fuzz Bear)
Message 2 of 8
(8,363 Views)
thanks
I tried as your words, but it does not work. quit a strange problem
Message 3 of 8
(8,359 Views)
any comments?
Message 4 of 8
(8,298 Views)
any solution to this problem? thanks in advance
Message 5 of 8
(8,264 Views)
Accepted by coolbear
coolbear,
there are some dynamically called VIs inside of NI Modbus toolkit.
Simply include entire toolkit into your application, and  all will be screwed up:
Test project in attacment (assumed that you have installed toolkit from here)
Andrey.
Message Edited by Andrey Dmitriev on 02-09-2009 12:37 PM
Message 6 of 8
(8,261 Views)
it works. deeply appreciate.
Message 7 of 8
(8,250 Views)
Hi Andrey Dmitriev,
I am facing same problem and i tried your solution, but i am not getting it,
I have installled ni modbus and using LV 86
regards,
Shrek
Message 8 of 8
(7,712 Views)
