memory subvi
Dear all,
I wonder how i can store data within a subVI when the iterating loop (an thus the shift registers) are in the mainVI (or in my actual case, four levels up in VI calling).
so far i solved this with a global array variable , but i feel this is not the way to do this. what is the best way for this?
Thank you for your advice!
(4,646 Views)
Accepted by topic author OPCler
Hi OPCler,
To store data within a subVI you should use shift registers (or feedback nodes) IN the subVI.
There is no "best" way - you need to look for appropriate ways!
- functional globals aka action engines
- notifiers
- global variables
- DVR
(4,636 Views)
Feedback node! thats what i was looking for!
(4,624 Views)
Hi OPCler,
in times before the feedback node we used to use while loops set to iterate just once to hold a shift register…
(4,614 Views)
what an evil hack ^^
(4,599 Views)
It is not a hack.  It is actually by design that we can use shift registers and feedback nodes to store state information ever since LabVIEW 2.0.
And you should also read up on the Action Engine.
(4,584 Views)
