Xy Graph x,y value programmatically change
     i  am using labview 8.2.want set x,y value programattically.for example i will give x min value 6(clock) and max 10(clock),interval 30min.so 6:00,630,7:00,7:30.....up to 10:00 how to set this type.i tryed using property node min and max property but this not give correct output
Message 1 of 8
(4,900 Views)
It really helps us to help you when you post a VI (actual code) that you've tried.  It would tell us, for example, what X and Y are (is X a TimeStamp?  Milliseconds?  A float?), would make sure what type of Chart/Graph you are using, etc.
Post Your Code!!!
Message 2 of 8
(4,872 Views)
You can only give the xy graph values programmatically.  But yes, let's see your code along with what you think it should be doing
Message 3 of 8
(4,849 Views)
hi,
         here i attached my code.i want to change x axis value programatically timestamp and decimal format.
Message 4 of 8
(4,808 Views)
hi,
Message 5 of 8
(4,804 Views)
Hi Gokul,
set the correct t0, format X axis to show absolute time and remove the checkmark at "Ignore timestamp in waveforms"…
Message 6 of 8
(4,791 Views)
hi,
       k now working.but interval not correctly set.i set 30min but it wiil take 20min or 15min  interval increamented.
Message 7 of 8
(4,778 Views)
Hi Gokul,
i set 30min
Where do you do this? Time values are in seconds, so you try to set a 30s interval…
It seems LabVIEW tries to adapt to your data. First set the data, then set the X axis formatting…
Right now you don't use waveform data anymore. Is there a reason you now use a simple 1D array?
Message 8 of 8
(4,772 Views)
