05-14-2007 05:51 PM
05-14-2007
06:30 PM
- last edited on
11-01-2026
10:57 AM
by
Content Cleaner
Message Edited by Support on 08-08-2008 11:28 AM
05-15-2007
09:59 AM
- last edited on
11-01-2026
10:57 AM
by
Content Cleaner
Message Edited by Caseyw on 05-15-2007 10:00 AM
Message Edited by Support on 08-08-2008 11:27 AM
05-15-2007 11:51 AM
05-15-2007 12:35 PM
05-15-2007 02:16 PM
05-15-2007 02:32 PM
What kind of processing is needed to join them? Could you give an example?
Would maybe SGL or I32 be sufficient for the output?
What do you need to do with the final array? Could you just append the processed segments to a binary file instead of keeping everything in memory?
Are you possibly trying to display the final data in a graph? In this case you should reduce the data because it does not make sense trying to display 12M of data on 1000 pixels of horizontal display space. 😉
05-15-2007 03:34 PM
05-15-2007 03:51 PM
05-16-2007 01:51 PM
I know that i cant handle the whole array at one time. so i take 2x10000 I16 points at 1 time and make 10000 CDB points array. with the CDB complex array, using bundle sub vi, i make the IQ signal. which i demodulate to waveform. this waveform is 2ms long.
finally i have 1250 waveforms, 2ms each. these i want to merge. I use merge waveform sub vi. here is where i run out of memory after 1218 iteration (ie, making waveform 2.4 sec )
I know its stretching labview to the limit. but is there a way i can do it all in RAM.
