maximum and minimum temperature
Good Afternoon, I have read several posts on how to fix my problem, but unfortunately I still have problem with my VI. I want the maximum and minimum temperature present on the front panel. I don't know if I must have 2 while loops or only 1. The problem in the current VI is, when you run it, it will stay in the inner while loop. So the minimum and maximum temperature will present always the same value. Could somebody tell me what I must change to let the VI work. Thanks for the help.
Message 1 of 12
(4,984 Views)
I can not insert my VI. How can I do that?
Message 2 of 12
(4,959 Views)
Attach your VI to your next post.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 3 of 12
(4,953 Views)
I cannot attach my VI. If I brows to the located place on my computer and insert the VI and click on "Add Attachment" nothing happen. It's really weird.
Message 4 of 12
(4,946 Views)
Under ATTACHMENTS, click CHOOSE FILE.
navigate to where your VI is, select it, and click CHOOSE.
The name should appear next to the CHOOSE FILE button in your browser.
Then post.
Steve Bird
Culverson.com
LinkedIn
Message 5 of 12
(4,942 Views)
I do exactly what you say, but nothing disappear when I post it.
Message 6 of 12
(4,937 Views)
Try a different browser.
Steve Bird
Culverson.com
LinkedIn
Message 7 of 12
(4,930 Views)
Just ZIP it and upload the ZIP file.  That's the easiest way.
Bill
CLD
(Mid-Level minion.)
Message 8 of 12
(4,926 Views)
Here is the zip file.
Under windows 8.1. I cannot upload the file. With windows 7 I have no problems.
Message 9 of 12
(4,922 Views)
Accepted by desley
Get rid of the inner loop so that the comparison is made every time a new number is generated.
There are additional things you can do to clean up the code, but that is essential.
Bill
CLD
(Mid-Level minion.)
Message 10 of 12
(4,906 Views)
