matlab linking problem
I had matlab 6.5 and matlab 7.2 on my computer, i uninstalled 6.5 in order to achieve some space, but due to this I am no more able to get matlab command window which usually appears when using matlab script node in labview. Is there any way to link the labivew path to matlab so that it can find matlab 7.2 which is still on my comp.
(2,718 Views)
Hi Agar05,
Are you seeing error 1047 when trying to Use The MATLAB Script Node in LabVIEW? If that's the case please try this link out: http://digital.ni.com/public.nsf/allkb/2B3FF46C8512C4F786256CF30071BE53?OpenDocument
If you are seeing other error codes or there are no error codes at all, please let me know. You can of course always reinstall Matlab 7.2, then the link to LV should be re-established once again.
Regards!
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(2,704 Views)
