match pattern
I have a string "hello" and "hellollo", and I want to find out either "llo" pattern or "llollo" pattern. But the regular express of (llo)+ doesn't work for me.
Many thanks!
(4,273 Views)
I think it works if you change the () to [] brackets.
(4,269 Views)
Match pattern uses a limited set of regular expressions terms.  Try Match Regular Expression
 EndigitBryan, the bracket will not match a pattern, but any of the letters in the set
e.g. 'l' in help, or 'oo' in hook
(4,243 Views)
You are right!  I should have thought about it longer.
(4,221 Views)
Of course "(llo)+" will also match "llollollo", "llollollollo", etc...
If you want to match only "llo" and "llollo", you'll need:
"(llo)|(llollo)", "(llo)()|(llo)", "(llo)(llo)?", "(llo){1,2}" or "(llo)\1?".
(4,193 Views)
