mass compile error
When I try to build the vi calculate location into an executable I get an error.
I have tried to mass compile the .llb it is located in but it returns a "bad vi"
I can open the vi with no problem in LabVIEW
Please advise
Dan Shangraw, P.E.
(3,282 Views)
It is a problem with your type definition. Just right click on Excel data members\Excel data members out and select disconnect from Type Def then click OK.
What's your version of LV ?
Message Edité par Steve Mohamed le 01-21-2009 05:57 PM
Steve M.
(3,268 Views)
My version is 8.5.1
Dan Shangraw, P.E.
(3,251 Views)
Note that the calculate location vi is the only one which makes any reference to another library.
My guess is that while LabView may know where this specific library is and use it when it needs to, when you attempt to compile the that vi into an executable, LabView does not by default attempt to copy the library as well, or has some error while trying to link with it. I have only recently begun using LabView, but have already noticed some querks while using outside libraries.
Just a thought...
(3,245 Views)
Accepted by ASTDan
 I think I solved the problem.  You have pointed me in an interesting direction.  When I build my application I deselect the "Disconnect Type Def" option, and I get a sucessfull build.
Dan Shangraw, P.E.
(3,221 Views)
