customize control
I want to customize  a boolean control. the result should be a sign like a valve. you can see it in the attachment. first i opened a boolean control. than i add two "raised right triangle" decorations and put them over the control. the problem is when i change the size of the boolen control the decoration size doesn't change.
Can anyone help me?
thx
Markus
(4,175 Views)
 Change to customize mode.
Right click on the control and select Picture Item.
Those are the pictures you should change.
Message Edited by Pnt on 01-22-2009 12:51 PM
(4,155 Views)
Accepted by topic author WeberM
I didnt get what u mean by should be sign like value.
However, i made a Control  that looks like a control u posted.have a look let me know thats what u want.
Ritesh
(4,148 Views)
Hi Ritesh,
thats what I want.
This control I can use it like a valve sign an show the status of the valve.
markus
(4,135 Views)
Hi Pnt,
thank you for your help. This was the way I need.
Markus
(4,133 Views)
