This widget could not be displayed.
mapping labview variables to teststand sequence context variables
hi,
how can i map variables from a vi (which is loaded in a test sequence in teststand) to teststand sequence context variables ?
if my question is not clear enough then plz let me know.
(4,951 Views)
First of all, there's a testStand dedicated forum. You should post there to get more answers.
Second, I'm not sure what you are calling "sequence context variables". what are you trying to achieve?
regards,
Rodéric L
Certified LabVIEW Architect
(4,943 Views)
so should i post it in teststand forum or can continue here ?
by "sequence context variables" i mean variables in teststand ( like Locals , RunState , etc...)
actually the thing is i have a vi to get input from user (which i've loaded in teststand as a step, call this sequence file as "S"), i need to store those inputs in teststand variables by accessing sequence context of S in labview (i've created corresponding variables in teststand).
(4,940 Views)
You can access TestStand variables from within LabVIEW using the sequence context but it needs some programming.
maybe, the best way to do what I think you're trying to do is pass the output of your LabVIEW VI directly to a TestStand Local variable (in the module adapter)
you may find this usefull: http://www.ni.com/pdf/manuals/323435a.pdf   Sequence context p.34
Rodéric L
(4,938 Views)
thanks Roderic
I tried doing wt u said, it worked  but i wanted to know the programming method. Can u help ?
(4,935 Views)
Sure I can help!
You can use either method:
Rodéric L
(4,917 Views)
