mac address pda
Can I use Resolve Machine Alias.vi, to get the MAC Address of my Touch Panel?. If thats right, haw can I use it?.
I was tring to use it in my pc and in the TPC without any success.
Thank you,
Juanjo
(12,663 Views)
There is no easy way to get your Touch Panel MAC address from a LabVIEW 8.2/earlier built application. If you just need to know the address, you can simply launch the command prompt on your touch panel and type "ipconfig -all". The MAC address is also usually displayed in the Network Utility dialog.
If you need to do this programmatically from LabVIEW, then you have to call CreateProcess using a call library node. Pass "ipconfig" and "-all" as the input parameters, then parse the std out parameter for the MAC address.
Refer to this KB for an example:
http://digital.ni.com/public.nsf/allkb/03EBFA9BE4718CEE8625722F0009C396?OpenDocument
miko
(12,572 Views)
I have proved the example and it worked. Now I`m traing to handle the output of the comand sending it to a file "ipconfig -all>\mac.txt". When I type it in the comand prompt window, it works, but when I pass the parameters to the vi is like passing "-all" only. I have attached a vi as an example.
Is there another way to do it without using a file, because you cant pass command line arguments to a pda application in Labview, am I right?
Than you Miko and sorry for my english.
(12,288 Views)
Sorry,
The VI...
(12,286 Views)
Hi Juanjo,
To capture the output of cmd, use "cmd" as the executable name and "/c ipconfig -all > \mac.txt" as the parameter. Replace "/c" with "/k" if you want to keep the cmd window open.
I created an example for you. Just open the attached mac.lvproj.
Message Edited by miko on 07-23-2007 10:28 AM
miko
(12,262 Views)
Accepted by Juanjo339
It worked.
Thank a lot.
Regads,
Juanjo
(12,248 Views)
