lvclass property node sub menu
Hello, i am relativly new to OOP in labview and have a question about creating accessor vis.
when you make an accessor vi available through property nodes is it possible to group them into sub menus?
i have attached an image below showing the property node for this VI where there are several sub menus in which more properties are located. is this possible in lvclasses? and if so how would i go about acheiving this.
(4,508 Views)
Accepted by carbon32
See here - https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/resource/framework/providers/vilibrary/cla...
Localized Long Name—Specifies the name that a Property Node using Name Format»Long Names displays when you access the selected property. This name also appears in the property selection menu that appears when you click the Property Node to select a property.
If you include a colon in the Localized Long Name, the property selection menu includes a submenu for the information following the colon.
You get to this page by right clicking the class in the project window and select Properties.
___________________
Try to take over the world!
(4,471 Views)
Thank you, i tried using clons and many other symbols in order to make the sub menu however i did not try putti them into the localized long name field.
as an addition to the original question,misnit possible to place a seperator bar in the sub menu? An example of this would be between the browse option and the rest of the items on the menu or when the properties fall under a more specific class in the class hierarchy?
(4,454 Views)
I doubt it. The lines are supposed to show the inheritance levels, so I'm pretty sure the only way to have them is to define the properties in child classes.
___________________
(4,435 Views)
I shall give that a go.
Thank you for the help.
(4,400 Views)
