loading vi's with operator interface
When I load a sequence file with my operator interface, I always get a message that the vi is already in memory. When I close LV in taskmanager and the load the sequence again, the error is gone too. Is this a configuration problem? Because my other system don't have this problem.
(2,989 Views)
Can you provide me with your files (sequence file and used VI's) so that I can test the reproducability of this error at my side?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,943 Views)
Accepted by JoVMo
Thierry,
I solved the problem with the dynamic loading setting in the step configurations. tnx!
(2,939 Views)
Great!
Thanks for letting me know.
If you would encounter any other issues or have some questions, then don't hesitate to let us know.
Kind Regards,
(2,921 Views)
please mark the issue as solved 😉
M
(2,919 Views)
