03-20-2012 06:01 PM
Hey guys,
I have to write load cell program with labview 6, but I have no idea how to do it.
If anyone knows, please give some hints.
Thank you
03-21-2012 12:02 PM
If you have little LabVIEW programming experience, the link below would be a good place to start:
http://www.ni.com/gettingstarted/labviewbasics/
I've also located a good example on ni.com/community that shows how to monitor a load cell in LabVIEW
https://decibel.ni.com/content/docs/DOC-2151
I hope this information is helpful.
-Nick-
03-21-2012 12:16 PM
I did see this example before I post question.
The problem is I don't know the math to transfer the input voltage to load.
And my labiew is version 6, i couldn't find any example regarding to force measurement.
03-21-2012 01:18 PM
Load cell is ageneric term that could be a piezo crystal or strain gauge.
Which type of load cell do you have?
The "Search Examples" worked fine in LV 6. Search for Hardware I/O >>> Analog input
Ben
03-21-2012 01:36 PM
Hey Ben,
I didn't see the hardware I/O in my search example.
I don't know how to convert the voltage to load again.
03-21-2012 01:43 PM
From LV
Help >>> Find Examples >>> Browse >>> Hardware Input Output >>> ....
Agian you should figure out the type of load cell.
One gives you a voltage and the other type gives a change in resistance.
Ben
03-21-2012 02:58 PM
I still couldn't fine the hardward I/O
Maybe because the version??
My load cell is SWO-10K for 10000lbs
Resistence is 350 ohms
rated output is 2mV/V
excitation voltage is 10VDC
