last bit in serial setting
Have you tried to do this with another terminal program, like HyperTerminal, if you're on Windows?
Message 11 of 13
(1,026 Views)
Maybe you can try to set "VI_ATTR_ASRL_END_IN" & "VI_ATTR_ASRL_END_OUT" to be 2. It can help you.
Message 12 of 13
(970 Views)
You are responding to an old post and in LabVIEW, the property names are Serial Settings:End Mode for Reads (short name ASRL End In) and Serial Settings:End Mode for Writes (short name ASRL End Out) and the value is an enum with a value of 'TermChar'. Giving the C code is just going to confuse people here.Smiley Wink
Message 13 of 13
(959 Views)
