publishing subvi
Hi!
I am working with an application on a network. I am having some problems when working with the subvi. When working with control from client computer, everything works fine. In this case, the subvis are shown on the screen when called. But when the server takes the control, and call these subvi, they do not appear on the client computer, but on the server one do.
Does anybody knows which could be the problem?
Thanks in advance
jm
(2,821 Views)
Hi jm,
At a time only one node can have control over the network. So you cannot have control from your client PC when server has taken the control already.
MRK (CLAD)
(2,747 Views)
Hi jm,
If you´re still experiencing the same behavior I would recommend the solution proposed in this KnowledgeBase:
http://digital.ni.com/public.nsf/allkb/970F4F6FDC30122786256F370077C72E?OpenDocument
CesarV
César Verdejo
Training and Certification | National Instruments
(2,728 Views)
