labview
How does one switch a vector from being a horizontal array to a vertical array in labview?
(3,481 Views)
A 1D array doesn't matter.  Only when you are trying to combine multiple arrays do you really need to worry about that.  What problem are you running into?
(3,476 Views)
I'm trying to do loads of arithmatic with multiple arrays.  Half of them are vertical and the other half are horizontal.  I guess my real question is- Is it possible to do arithmatic with arrays that are not all vertical or not all horizontal?
(3,471 Views)
Oh yeah, and I'm working with all 1D arrays.
(3,469 Views)
Accepted by topic author a1wd3
Are you referring to how the 1D arrays are displayed on the front panel?  In the actual data, it is just a 1D array.  It doesn't matter if the front panel shows the array vertically or horizontally.
(3,468 Views)
Thanks! I'm a super-beginner right now so I think the way the front panel displayed it to me just was a little confusing.
(3,460 Views)
