labview with access database
Hi everyone:
I am using labview opc server collection data from 5 plcs then store into access then someone can query these data later.
Problem is i can not combine 5 plc`s data into one table,now 5 plc`s data in 5 different data table and all the data collecte are in 5 tables in access database
Does someone now how to put all the data in one table and all the queried data are in one table.
Message 1 of 8
(4,483 Views)
From What I see, you need to cleanup your code.
Second, please send you VI... the picture is not enough.
Benoit
Message 2 of 8
(4,477 Views)
Message 4 of 8
(4,424 Views)
it works now thanks
Message 5 of 8
(4,391 Views)
Accepted by topic author 314159ym
Hi pi number,
it works now thanks
How did you solve your problem?
Maybe that could help other people stumbling over your thread! (That's how this forum actually works…)
On your VI:
- Please use only English chars (aka plain ASCII) for filenames as using asian UniCode chars will give problems for most users.
- Please remove those Rube-Goldbergs in your code! Why do you need to compare boolean values with TRUE?
- Why do you need shift registers to handle all those buttons?
- Why do you need to create events using that additional while loop and property nodes? Why not react on button value change events directly?
- Why is there a wait function in the event loop? Why don't you use the Timeout event instead, even though you have that event case? (In your VI you don't need both the wait function nor the TimeOut event!)
- Use AutoCleanup, set string constants to "size of text"
- Never use that "Exit" function in your code: its like using a tree to stop your car! End your VI in a graceful way instead…
Message 6 of 8
(4,380 Views)
I used the "insert into new_table    select (a.1,a.2....  b.1,b.2......)   from tableA,tableB where A.ID=B.ID"
After this then i select the data from new table
Message 7 of 8
(4,356 Views)
It looks like the Where is badly formatted with the dates written merged with the And. "Where  [field] between #2018/1/1#and#2018/12/31" looks strange, i'd assume the spaces around "and" are important so it should be "Where  [field] #2018/1/1# and #2018/12/31#"
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(4,347 Views)
