Overview
Sometimes, you get given data as lots of little files, and you want to join them all together in one big spreadsheet for analysis. This VI allows you to do that.
Description
The best way of getting all your data in one file is to put it there immediately when it's generated. However, not everyone adheres to best practices for data control, so sometimes you can be given large numbers of smaller files, perhaps from different test runs, and asked to join them all up in to one file.
This VI will open and read data from multiple ASCII files and concatenate the numbers in to a spreadsheet. It assumes that each file has the same set of rows and columns, and that you just want to add each one in below the last: if you wanted to change this behavior, it could be done by modifying the constants being inputted to the concatenate strings function.
Requirements
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
can you please upload the file in previous version?
Hi Phanisri - what version of LabVIEW would you like me to add a version of this VI for?
How can I concatenate multiple tab-limited text files containing Date, Time, Failure Status information into one spreadsheet file & then plot a graph?
