Automatic creation of headers in CSV file if there is no headers
Hi all i would like to ask how can i make my programme automatically create headers for my csv file if the file has no headers in it.
i have tried to troubleshoot on my own but to no avail.
For the "test excel(1).vi" file, the headers will be generated every time i run my vi( repetition of headers)
For the"test excel(2).vi"file, the headers must be manually entered into the csv file.
Message 1 of 17
(4,317 Views)
Results of test excel(1).viResults of test excel(1).viResults of test excel(2).viResults of test excel(2).vi
Message 2 of 17
(4,315 Views)
Accepted by topic author edmund99
Here you go with that solution, It might help!
Message 3 of 17
(4,310 Views)
Hi thanks Mr Sabari , may I know what is the vi you placed at the case selector of the case structure?
Message 4 of 17
(4,298 Views)
Hi Edmund,
2 hints:
- it's a comparison function...
- it's used to test an array...
One more hint:  sabari attached a snippet!
Message 5 of 17
(4,285 Views)
It's a Read Delimited Spreadsheet.vi. If you got a solution kindly accepted as a solution. So, no more conversation wouldn't go about this topic.
Message 6 of 17
(4,272 Views)
Hi Mr Sabari this is the vi that i wanted to ask you about
Message 7 of 17
(4,265 Views)
That's an empty array.
Message 8 of 17
(4,260 Views)
its "Empty Array?" function in comparison palette. if read file function returns empty array, then write header (1st case structure)
CY (expired CLAD)
Message 9 of 17
(4,264 Views)
Hi i am still unable to generate headers in my excel.
Message 10 of 17
(4,246 Views)
