labview runtime - slow pc start up
Hi Luke,
Resurrecting this old thread, I have tried the method you describe, but not having much success.
I can see the correct ProviderID in the registry, I can see how it should be re-shuffled to get the GUID, but I cannot actually run the command you described.
I have tried by coping the GUID directly from the nimdnsNSPTool.exe -list output, but it does not seem to work, I get FAILED (10013) response. Do you have any tips on what may be wrong here?
EDIT: it seems I have to run this from a command prompt that has been opened with Administrator priviliges
Message 41 of 53
(8,393 Views)
Hey Neil,
Did the workaround end up being successful?
Message 42 of 53
(8,365 Views)
Nice to see that this problem got "priority" in 2012 (http://forums.ni.com/t5/LabVIEW/labview-runtime-slow-pc-start-up/m-p/2263060#M716777). Today is 2015 - and it's still present and can be solved by the same method (disabling the NI mDNS component).
Message 43 of 53
(7,556 Views)
I can also confirm this registry fix. I use a lot of virtual machines, and it took me a long time to track this down. It started manifesting on a LabVIEW 2012 virtual machine, but it was inconsistent across several instances of that VM on various hosts. It also happened on LabVIEW 2013 and 2014 VMs, again, inconsistently across various hosts. Even after thinking I fxed it, it would re-appear.
This registry fix definitely did the trick. The symptom was slight different on a VM using VMWare Player. I experienced that the VM would boot as normal (fairly quick), but the Start Button/Orb and taskbar were missing for about 15-30 minutes, and then would eventually appear. After implementing the registry fix, I have rebooted various VMs on various hosts and have not seen the problem again.
Message 44 of 53
(7,044 Views)
Breating some new life in this topic I come here with the concluding answer (especially for 64-bit):
The executable to use is nimdnsNSPTool.exe
These lines you can include in your deployment:
"C:\Program Files\National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
"C:\Program Files (x86)\National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
This will remove both instances of the problematic Service and make sure you can log out and in in an orderly fashion.
Cheers!
Message 45 of 53
(6,899 Views)
I would love to use this method because we are installing 70 computers in the next weeks and always have to do a manual regedit afterwards.
Where can I include those lines in the deployment? I did find "Start program after installation", but i can only start one program and have to include this program into the project. Is there anything I'm missing? Using LV 2013.
Message 46 of 53
(6,748 Views)
depending on how you need to run them, you may be able to string together a couple executables in a batch file:
http://digital.ni.com/public.nsf/allkb/ED185175604CAA86862579BA00593002
Message 47 of 53
(6,725 Views)
We are using these lines in our installation:
(this is just a small part of the installation script)
:: Removing nimdnsNSP
set nimdnsNSPTool=National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe
if not exist "%ProgramFiles%\%nimdnsNSPTool%" goto nop
echo .
echo Removing nimdnsNSP
"%ProgramFiles%\%nimdnsNSPTool%" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
if not %errorlevel%==0 goto error
if not exist "%ProgramFiles(x86)%\%nimdnsNSPTool%" goto end
echo .
echo Removing nimdnsNSP (32-bit instance)
"%ProgramFiles(x86)%\%nimdnsNSPTool%" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
echo Done!
goto end
Message 48 of 53
(6,615 Views)
Scratch the above, we've made it much simpeler. Also this is compatible for 32-bit and 64-bit:
:: STOP AND DISABLE nimDNSResponder Service
NET STOP /Y nimDNSResponder >NUL 2>&1
SC CONFIG nimDNSResponder START= DISABLED >NUL 2>&1
Easy and fast!
Message 49 of 53
(3,390 Views)
Hm, just stopping the service doesn't quite cut it.
Tried it twice here now (damn that install takes long)
Fixxing it now so we will have a decent installer soon!
Message 50 of 53
(3,370 Views)
