labview no longer runs after windows update
Running Windows XP 32bit w/ Labview 2012 SP1 - Windows auto-updated on May 11, 2013.  After update, Labview hangs on startup, nothing fixes it.  Tried restarting and all the usual nonsense.  You can open VIs, but then the CPU goes into a state of either 50% or 100% usage (seems to be random) and Labview just hangs w/ hourglass icon and never responds.  I can open NI MAX and querry various instruments, but Labview itself (either startup or any VI) just hangs.
I need fix ASAP, scientist on very tight deadline, can't wait for NI to open their doors on Monday morning.
PLEASE HELP!!!!!!!!!!!
Message 1 of 22
(5,446 Views)
Tried Labview 2012 SP1 (32 bit) f2 patch - but the patch tells me there is nothing to install.
http://joule.ni.com/nidu/cds/view/p/id/3842/lang/en
Message 2 of 22
(5,444 Views)
Attempting repair install now ...
Message 3 of 22
(5,430 Views)
Ouch!
Have you tried to repair the current LabVIEW installation?
What are your computer specifications? Do you have unusual hardware (many CPU cores, certain AMD processors)? What were the updates?
Message 4 of 22
(5,428 Views)
This happened to me not too long ago. A clean install (after 3 tries) fixed it.
My plan for future proof. No internet access on my work laptop and no more windows update (burned many times with other apps.).
kas
Message 5 of 22
(5,421 Views)
Repair install did not fix anything - thanks for the response.
My specs are:
HP workstation
Xeon CPU 3.8 GHz (single core)
3.25 GB RAM
Win XP Prof SP3 (32bit)
I suspect this is a special build by HP for my workplace.  Computer has always run Labview without problem, first time I've encountered an issue.  Perhaps the Win Update has simply made Labview incompatiable with XP, and since the update was only applied yesterday I'm the 1st person to report it.
Message 6 of 22
(5,415 Views)
There are two recent updates:
Hotfix for Windows XP (KB9545505-v5)  5/10/2013
Hotfix for Windows XP (KB961118)  5/11/2013
I could look these up, but I'm not a Windows Guru and I doubt I would understand how the changes matter.
I'll try the clean install, see if it works.
Message 7 of 22
(5,412 Views)
Support pages for the updates:
http://support.microsoft.com/?kbid=961118
http://support.microsoft.com/?kbid=954550
One updates .NET Framework 3.5 SP1, the other MS XPS.  I do not know enough about how these featurs would affect Labview to diagnose.
Message 8 of 22
(5,409 Views)
I am not really technically knowledgeable in windows OP, but I suspect that you may not be able to solve the issue without involving NI (for which you do not have time). A clean install may be a shortcut to resolving the issue.
Kas
Message 9 of 22
(5,404 Views)
Just another random suggestion: have you tried renaming the existing labview.ini file?
Message 10 of 22
(5,399 Views)
