labview.exe generated error
"I am using LabVIEW 6.1 in windows 2000. I downloaded the Agilent3499A IVI from the website and configured the driver and everything. When I run the Initialize.vi, I have this following problem.
LabVIEW.exe has generated errors and will be closed by windows. You will need to restart the program. An error log is being created.
I don't know where this error log is getting created.
Any help will be appreciated. Thanks"
(2,913 Views)
I have the same problem/ error when I try to run my VI controlling R&S CMU200, and it was due to wrong GPIB Address on the equipment.
Would it be the same problem? How about checking that the equipment's GPIB address set is same to that the Initialize.vi is wired to.
It may not be the problem but no harm to try.
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,913 Views)
Error logs are found in the Event Viewer (Start>>Settings>>Control Panel). If a driver is installed correctly you should be able to run the Getting Started VI (there may be a whole pallette of Getting Started VIs) and the only setting you need to modify the address of the instrument.
Ray K
NI Applications Engineer
(2,913 Views)
