Showing results forĀ
Search instead forĀ
Did you mean:Ā
labview excel with activex
Hello everyone,
during my intership i have a project where i have to add some data to an excel file which already exist, i have to use activex but no idea how to use it, is there some vi available where i can give a file and the coordinates of cells where to writte
using labview 2014, beginer on labview
Message 1 of 29
(20,304 Views)
Accepted by topic author louis293
Try This
Palanivel Thiruvenkadam | ą®Ŗą®“ą®©ą®æą®µąÆ‡ą®²ąÆ ą®¤ą®æą®°ąÆą®µąÆ†ą®™ąÆą®•ą®Ÿą®®ąÆ
LabVIEWā„¢ Champion |Certified LabVIEWā„¢ Architect |Certified TestStand Developer
Message 2 of 29
(20,289 Views)
thanks a lot, do you by chance have the vi so that i can dowland it ?
Message 3 of 29
(20,277 Views)
i don't manage to drag and paste, can somebody put the VI file  please ? thanks in advance
Message 4 of 29
(20,252 Views)
Hi Louis,
left-click the image to start the image viewer of the NI forum.
Then you will see a download button below the image: save the image to your harddrive.
Drag the image file from your harddrive into an empty VI block diagram.
Finished.
Message 5 of 29
(20,240 Views)
well the probleme now is that i have the labview 2014, doesn't work with this file.
Message 6 of 29
(20,237 Views)
Hi Louis,
here you go.
(You could state your LabVIEW version in your signature to aid other to provide VIs in the needed version…)
Message 7 of 29
(20,230 Views)
thanks a lot, but it still doesn't work but i think it is an individual error (it will probably work on other computers), when i run an error occur , and when i open the excel file after it didn't change as expected and it is suddenly only lecture mode available
the error is error -2147352565 index not valid
Message 8 of 29
(20,224 Views)
Hi Louis,
index not valid
The VI will select a certain Excel sheet: you have to provide a valid sheet name!
Message 9 of 29
(20,202 Views)
i think i gave a valid one, i used the path button to specify the file, i don't know what i can do better
Message 10 of 29
(20,196 Views)
