labview email.
Ignore the names of the attachments, I realise they say 7.0 but I just forgot to change their names when I converted them back a version.
I promise they are really 6.1 versions
Emma R
NIUK & Ireland
Message 21 of 31
(2,545 Views)
Hi EmmaR,
i was happy to find the email-vi's for LV6.1 as i still use this Labview-version.
Unfortunatly the vi: Email_with Attachment_7.0.vi doesn't work for me. I get an error (in the erro-out messagebox).:
"object specified is not creatable in Email_with Attachment_7.0.vi"
Is there something wrong with the vi or do i something wrong?
Joop Tap
Message 22 of 31
(2,485 Views)
hello Emma, i have a problem with the Automation Refnum, i  get the  , an what toldsme is: error number 3005 (Automation Open: Object specified is not creatable in Email_with Attachment_7.0(2).vi)
thank you
Message 23 of 31
(2,138 Views)
thank you
The two last post are most likely due to not having the correct MS Office installed on that computer. Outlook being an MS Office application and MS changing the object library it implements those ActiveX interface usually with every new version including the ActiveX object structure made it virtually impossible for LabVIEW to allow use of MS Office ActiveX controls across different versions.
Most probably you can fix that by making sure the Outlook ActiveX library that is installed on your computer is referenced instead of the one the original developer was using. You may have to go into each ActiveX Node too and reselct the methods and properties to allow LabVIEW to link properly to them and if things go very bad (but it's not very unlikely) you will also have to look for differently named methods and properties and/or rewire them since their interface changed. Maybe you can't even replace certain functionality since it got only added later on with newer MS Office versions.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 24 of 31
(2,124 Views)
The code that you are trying to open is stuff I wrote 2 years ago. If you read the entire thread you'll see that it's dependent upon an ActiveX control from Ostrosoft to generate the email. The free version of the control is still available, check the company website.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 25 of 31
(2,108 Views)
Hello mikeporter
I am trying to use the library that you said but, it gibes me this error.
Class not registered
I don’t know what to do.
Thank you.
Merardo Vela.
Message 26 of 31
(2,062 Views)
Hi,mikeportor,
    I find so many file from the thread,which one is need?Would you like to tell us the details?
Thanks.
Labc
Message 27 of 31
(2,050 Views)
Dear all,I find this thread from http://www.ostrosoft.com/smtp_component.asp and registe OSSMTP.dll in windows system.However,it takes a long time at the node "SendEmail",and i can't stop it by Abort Execution also.
Why?
Thanks.
Message 28 of 31
(2,043 Views)
Have you tried pinging the SMTP server you are trying to talk to?
Mike...
LabVIEW Champion
Message 29 of 31
(2,023 Views)
Sure,I can access it in my brower(http directly)or Ooutlook Express.
Message 30 of 31
(2,008 Views)
